Eds Vans RV-6A/7A Web Site
Date:  2-19-2008
Number of Hours:  0.00
Brief Description:  Trimmed and drilled the wing walk doubler plate.
First you trim 2 wing walk doubler plates from larger stock sheets.
You then clamp the trimmed sheet under the inboard top wing skin and match drill all the holes. I drilled right into my bench and put clecoes in the holes to hold it in alignment. I held the shop vac close to the hole to avoid cleaning up all the aluminum chips later.
First trim for length, then for width.
Match drill the holes.
Trimmed to size and holes drilled.
