Brief Description: Scotch bright all main wing ribs.
This was another daunting task. I bought a hole box of scotch bright pads from Avery Tools. I cut 1 pad into 4 smaller pads. One small pad was good for only 2 ribs. I started by smoothing out the lightening hole inside edges. Moved on to wire holes I drilled. Then the rib flanges and finally web faces. Took for ever. Not much fun. It's like taking a jog, you just want it to end. I still have the leading edge ribs to do. Oh boy.
You can see in the picture of the things I used for the task. 1. Red Scotch bright pad box. 2. Alcohol to remove the Vans part number sticker. 3. Vibrating pencel to etch the location and side that the rib belongs to. I had a Sharpie designation but the Scotch Bright pad would remove it. 4. A bunch of used debur pads. 5. Raw sore hands.
Ready to clean and prime ribs. Prime rib? I'll have that for supper.
