Brief Description: Drill rudder bedal bearing blocks to 719 stiffener
Not much to say here. I did however use strong double sided tape between the bearing block and stiffener. My blocks are 1” apart for the 3 different locations. Not 1 1/16”. Just 1”. I was going to go with 1.3” because it would have expanded my adjustment and the hole pattern still would have been good on the end 4” end bearing blocks. But then I looked at what the hole location would have been on the center 3.5” bearing block. I would have had holes almost intersecting. So, I just stuck with the 1” spacing.
