Brief Description: Prime 706 through 712 bulkheads.
Image 1 shows the bulkheads simi preped. All the part number stickers are scratched off and I used MEK to remove the sticky remains. Also, I have found that its a good idea to remove the blue sheet metal lettering before you polish the parts with a Scotch Brite pad.
Image 2 shows the bulkhead parts polished with a Scotch Brite pad.
Imgae 3 shows the bulkhead parts primed. I used the Stuart Systems water born spray gun primmer. I thought I was going to switch to the SEM Self Etching rattle can primmer but I've changed my mind. I used a whole can on just the 705 bulkhead parts. Are you kidding me. $18.00 bucks and that's all it did.
