Brief Description: Firewall - Match drill 601J's to firewall. Part 2.
Drilling the 601J. No big deal really. Although I was shaking a bit. Why do I do that. I'm afraid of messing up I guess.
The only thing to worry about is that when you drill the holes in the corner of the 601J from the other side of the firewall, make sure you don't angle the bit towards the corner. You see, the holes are close to the corner with a straight hole. If you angle in, your'll be in trouble.
You can't see it but the601G under the 601J is in place. It's just hidden from view.
