Brief Description: Firewall - Fit parts on firewall, Part 2.
Image 1 just shows a close view where stiffeners, spacers and gussets come together.
Image 2 shows the one stiffener that you need to make yourself from angle aluminum. Same process to make it, band saw, belt sand, scotch bright. Perfect fit. The glove I use because these parts get hot belt sanding and scotch brightening.
