Well, another tool to make life easier. This is a washer wrench set. These guys hold standard aricraft washer sizes. The ailerons get bolted on and you need to fit several washers on the bolt but the bolt goes through a hinge. You need something like these to line the washer up with the bolt your pushing through. Not sure how you would do it with out these.
I shopped all the popular aircraft tool supply houses. They all seemd the same so it came down to price. The best price conbined with priority shipping was at www.YardStore.com. Item number 50199. Cost was $29.95.
The description is "Slip washers into hard-to-reach areas with ease. Made from 301 stainless steel 0.042 thick. Will hold 8 different size "AN" washers. Set includes all four pieces."
