Here they are. Aleron hinge brackets riveted up. Special attention needs to be spent on keeping - The parts together. Which holes get counter sunk. Rivet direction.
You actually use a rivet length of 11 on these guys. I found that using the thin 1/8" universal set and thin flat set made it possible. I don't thing I could use my squeeser to rivet a length 12. Length 11 seems to be the maximum. Anything longer then 11 needs to be bucked.
Notice the unprimed polish look. I did prime the mating surface of the angle stock however.
