Eds Vans RV-6A/7A Web Site
RV-7A
Wing rear spar preperation.
This is the wing rear spar.
The alerons and flaps will anchor off it.
The flange edges need to be filed down and smoothed out.
I used a scotch bright wheel in an air grinder and a fine scotch bright pad.
Scoth bright wheel in air grinder.
Made quick work of it.
Finish with file scotch bright pad.
Aerolite 103 Home
RV-6A Home
RV-7A Home
Finishing Kit
134
Flap Actuator
Hole Fixing
Personel
Roll Bar
57
Seat Back
Shop
Wing Cradle
Wing Hardware
Wing Jig
