Brief Description: Bending the elevator trailing edge.
The gap between the 2x8's needs to be larger then the bend radius of the trailing edge of the elevator. I had to re-install the hinges to make this so. Its clamped to the work bench. 2 more clamps used for leverage.
I have about an inch and a half between the leading edge skin and spar. I just couldn't get it to bent any more.
