Eds Vans RV-6A/7A Web Site
RV-7A
Drill and rivet F-789 elevator push rod.
Using the usual method of evenly spacing hole marks on a piece of paper equal in the length to the circumference of the tube.
Using the drill press I clamped a block of wood on the table as a fence to assure the holes went straight through into the tube.
Time to debur and rivet. I couldn’t get the end bearing out to debur so I did the best I could by sticking my debur tool in the holes.
F-789 Push tube holes marked.
Drill F-789 push tube ends.
Debur and rivet F-789.
Aerolite 103 Home
RV-6A Home
RV-7A Home
Finishing Kit
134
Flap Actuator
Hole Fixing
Personel
Roll Bar
57
Seat Back
Shop
Wing Cradle
Wing Hardware
Wing Jig
