Easy drilling here. I had pre drilled the holes in the vertical attach bars, so its an easy matter to match drill the HS rear spar through them. I used a square to help line up the drill bit and keep it square.
I did my typical AN3 bolt hole drilling. Start with a #30, followed by my 2 step 0.187 drill bit, finalize with my 3/16 reamer.
