Brief Description: HS center bearing is not Perpendicular to spar.
Notice in image 1 I put a 12” #40 drill bit through my drill bushing. Why you say? Notice the drill bit is not parallel to the trailing edge of the skin. I put a ¼ inch drill bit through and tweaked it slightly. Image 2 now shows its parallel.
