Brief Description: Roll Bar - Bend and drill the 732D angle.
Here we need to bend the 631D angle by 2 degrees. Not sure what others have done, but I just squeezed it a bit in the vice. Good enough.
To locate the angle at the top on the roll bar channel I used a 9/32” spacer between the angle and the top of the roll bar channel. Clamp and match drill through the opposite side.
