WOW.... I think I should be building a tail dragger... The tri-gear mount is a bear to work around for both the fuel and brake lines. I showed photos in the previous log entry that worked for the fuel lines. Trying to get the fuel / brake lines to pass through / around / over the gear mount is almost impossible using the Van's routing pass through tubing mounts.
I have went through about 6 ft of brake line just trying different routes to see what looks and works the best. I have a functioning concept but it does not look as professional as I would like.
Looks like I will be ordering some more brake line... I am even thinking of getting custom made steel braided lines... I will work on a few more ideas this week.
