I have been thinking for the past few days about how I will securly guide the Pitot / AOA plumbing around the bell crank / control system.
I fabricated this guide bracket that will share the bell crank mounting hardware. Simple but effective. It is fairly ridged and seems to work exactly the way I want. I am going look around at other builder logs to see if there is a better way.
Update:
I was looking around at ideas on routing the Pitot/AOA through the bell crank area. Some folks are actually routing it under the bell crank, not sure I like that to much. Some are using ridged aluminum tubing from the Pilot/AOA through this area and then continuing through the rest of the wing with the flexible tubing, that I like... I am happy with what I have, so I will continue to invite ideas from my area builders...
