Brief Description: Left Wing Bell Crank / Pitot/AOA System
I sent the photos of the bracket to Van's and asked if they thought it would be an issue using the bell crank mounting hardware to route the Pilot/AOA plumbing. Van's thought the bracket was fine idea and mounting it along with the bell crank hardware was acceptable.
I received the 1/4" reamer from spruce, along with a few other things I needed. I reamed the brass bushings and fitted the bell crank. I then drilled the remaining holes, deburred, inserted the plastic bushings and routed the Pitot/AOA tubes.
I will be putting the final touches on the Pitot/AOA bracket, powder coating and installation.
