Finished the final fitting of the Vert. Stab. Fitted the tie down mount and drilled the vert stab to the aft bulkhead. Bolted the Vert Stab in place temporarity. check the demensions, everything checkout great. Mounted the Rudder to check fit and travel. I have a couple other holes to drill on the Horizontal Stab front spar and F-798 shims. Fitted the empennage fairing, which surprisingly fit like a glove... I trimmed to clear the elevator control arm, and the rest just snuggled right into place. No apprecible gaps to speak of...
