Inspecting the oil cooler after the second engine run... I still saw a small oil leak around the bottom fitting.
I removed the oil cooler and re-sealed and torqued the fittings. This time I used LocTite 569. I drained the oil through a filter for a couple of days... no visible contaminates. Removed the oil suction screen, inspected, cleaned in solvent, and filtered... No issues. Removed oil filter, cut and removed filter element, inspected, cleaned in solvent and filtered. Everything looked great...
