My RV-10
Date:  1-19-2014
Number of Hours:  2.50
Brief Description:  Second Engine Start - Successful
Started the day by fixing the decrepancies from the First Engine start...
Rerouted the #2 exhaust gas temperature probe.
Tighted the lower oil cooler AN fitting.
Checked entire engine for any oil / fuel leaks - ALL check OK.
Adjusted the Tach pickup in the Skyview EMS settings. Set to 2 pulses per revolution.
Drained about a quart of oil from the sump through a fine paint stainer - No visible metal/debris.
Check color for excessive blow by... color normal, minimal darking.
Ran the engine for 20 minutes...
Tach indications were correct, OK
#2 exhaust gas temp indicated the same as yesterday... Will swap probes to check.
It's about 70 degrees lower difference.
No oil leak around the lower oil cooler AN fitting - OK
Taxi test was successful... run-up with brakes only.
Had my GoPro inside the cockpit today, focused on the skyview.
Post:
http://www.youtube.com/watch?v=sgo0syjJwog
CFT vs EGT
CFT vs EGT
Oil Pressure vs Oil Temp
