My RV-10
Date:  7-18-2012
Manual Reference:  Sec 9 DWG 42
Brief Description:  Canopy Frame
Started by installing the top skin, cleco'd from underneath to allow movement of the canopy frame.
Drew a center line down the top skin marking the rivet / center line of the rib.
Drilled 2 pilot "Screw" holes in the C-762 canopy slide rail, 1 forward, 1 aft.
Positioned the slide rail on the center line, and 1/2" forward of the rivet line in the back.
Double checked the clearance and drilled through the skin and rib using the pilot holes as a guide.
cleco'd the slide rail in place, and checked the movement of the frame forward and back.
The clearance couldn't be better... there is only about 1/4" on each side of the frame and skin.
Canopy Frame in Position
Canopy Aft Position
Canopy Aft Position
Canopy Forward Position.
