Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6b13-1
bending flange on hardwood 1 of 6
The following 5 entries and 18 pictures show the main features of bending a flange in .060" 6061-T6 using a hammer, hardwood and whatnot.
Tapped .060" steel shim to help keep the clamping force level along the flange.
The board on top has the .25" radius on it. First line everything up and clamp boards parallel to each other
Trimmed and marked for bending
Shim of .060" steel
Board are same width, clamp
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
