Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Fitting rudder bearing and spar jig
The pedal bearing was about .520" thick, ground it down to .505 and the movement is much smoother now.
Checked dimension and test fit the main spar jig.
Getting ready to bend the Wing Attachment Uprights.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
