Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6ATO-1
Aileron trim tab 3 of 3
Tested and measured servo so it could bet set in the middle of it's travel. Clecoed servo in position and set the bracket, then cut the rod to length.
Test and measure servo
Set Bracket
Mark rod and trim
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
