Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W00
Setting Flaps for Alieron reference 2 of 4
Set the flap with two 3mm offset blocks with double sided tape. Set the blocks near the ribs right on the lower rear wing skin. The third block in image 3 sets the nuetral position
3mm offset for flaps
3mm offset from below
Set flap in nuetral poaition
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
