Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W1
Assemble and rivet Flaps Step 2 - 4
Step 2, top row leading edge of flap. cleco pattern Rib 4, rib 3, rib 5, rib 2, rib 6, rib 1.
3 rd step, Flip part and add clecos to the flap top forward row using the same pattern. The cleco the bottom hole of the flap leading edge.
Step 4 Flip part, remove clecos from the bottom and fixture in place.
2nd step
3rd step
4th step
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
