Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W2
Assemble and rivet Flaps Step 1
The next 12 pictures show the order of operation I used to assemble the Flaps.
I first set the line pressure so it just pulls the rivet as I set the rub plates on rib one.
Cleco Ribs to bottom at the ends, it makes it easier to close the part.
Set line regulator
Set line pressure
Assembly step 1
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
