Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Carb heat cable placement
Modified a 1/4-28 bolt to clamp the cable end and act as a pivot point on the lever. Using jam nuts to hold the cable at the through hole in the bolt.
The test worked so it's only going to take one adel clamp and a couple layers of shrink tube to hold the cable in place.
test idea
Closed
Clamped
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
