Putting mixture and carb heat controls on the center console, can be reached from either side easily.
Have three cables through the firewall in the upper left near the main power. Carb heat cable is going down in this picture, the other two are left throttle and mixture.
Have a straight shot from the oil pan threaded hole to the carb mixture lever.
