Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Cleaning things up on the engine
Having the air shroud high enough allows the dip stick to come out. Changing the oil and marking the stick the next couple of days.
Added a quick drain to the oil pan.
Moved CHT temp probed to the correct location
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
