Oil temp? 160 1st read 180 b side 2nd read 185 after about 1hr run on a side
1st read Full throttle rpm? 2600 on points @32degrees not leaned out first run, 2620 warmed up (oil temp 180) 2nd read 2640 after about 1hr. On the a side not leaned
Temp probe at cabin heat duct? Half carb heat valve at intake plenum produces 134 degrees f at the cabin
Check alternator output ACV 22 @1980rpm 33 @ 1810 later
