The fuel line to the wing was 1/2" too short! So I cut out the aweful section that runs through the MLG mount and added a new section that runs under the mount instead. Used a M-M fitting to join the tubing. Dimpled Horiz Stab bottom fairings and countersunk drilled the fuselage side holes for the fairings.
