Brief Description: Preping for mating wing to fuse
While trial fitting alignment pins into centersection spar bolt holes, found the only the bottom two holes of the web portion had not been match drilled to the actual spars and were slightly undersized. There was NO WAY the 7/16" taper pins would go in. Using a step drill, cleaned up the hole face and the pins then fit snug as a glove.
