Mounted oil cooler to rear baffle and rigged the cooler oulet shutter. Used two washers between shutter door and cooler face so that some air can always make it through cooler and also in an attempt to make up for the area that the shutter does cover even when "open". Made up cable fastening post to secure cable for control lever arm. Works great!
Oil cooler mounted to rear baffle
Cooler shutter louver mounted. Fabricated bracket for remote cable operation
