Mikes RV-9A Web Site
Date:  10-3-2009
Number of Hours:  3.00
Brief Description:  LSE Elect coil wiring
Used the ignition bulkhead fitting as a drill template to the baffle. Used a 3/4" unibit to drill out center area then finish out with with a file. Made up hot lead connections to coils and checked for proper fiing per LSE manual.
Use of bulkhead fitting to matchdrill holes in baffle
Used a 3/4
Used a 3/4" Unibit to drill out center
LSE EI coils wired and hot
