Using Safety Poxy and flox mixture, made a bead of flox under the windscreen to seal it to the skin, then spread a filet of flox along the front edge. By getting this to cure overnight, I'll be able to do the fiberglass fairing layup tomorrow. Using a small electric box fan heater I made a diffuser to blow warm air over the canopy during the night. Otherwise, the garage temp will fall into the 50's overnight and it will take all week to cure at that temp! The goal is to have it set up by morning but still "green" so the glass layup will still chemically bond to the flox.
