Mikes RV-9A Web Site
Date:  7-24-2010
Number of Hours:  1.00
Brief Description:  FIRST FLIGHT!
Saturday 7/24 at 0850, I performed the first flight of my “quickbuild” RV-9A, 9-1330, from the Mothership homebase of Aurora, Ore.
Wind was 10-15 mph straight down runway 35, acceleration was swift, and on lift off the airplane flew “hot, straight and normal”. With neutral elevator trim at rotation, it only took about ½ turn “down” to set climb trim. Climbed at 100 mph to a racetrack around KUAO at 3500ft at full throttle (26” MP / 2400 RPM, 82% Power, full rich, resulting in 14 GPH) for initial engine break-in. CHT’s stabilized at 380 to 410 and at 30 minutes into the flight, in a manner of a few minutes, all four CHT’s dropped 40-50 Deg, indicating that the rings had broken in. Oil temp was stable throughout the flight at 183.
Full power was maintained for 45 min, then throttled back to determine stall Vs IAS. Clean stall buffet occurred at 58 MPH IAS, 20 Deg Flap buffet at 53 MPH IAS. Entered the traffic pattern at 85 MPH, turned final at 70 MPH with 20 Deg flap and made a greaser landing! WOW…. What a sweet & honest airplane!!!!!!!!!!
General flight observations:
Rudder authority on take off is immediate.
Manual pitch trim is very sensitive.
Control stick flight pressures are pretty high, but well balanced.
No heavy wing.
I have about 1/3 diameter of a GRT EFIS ball left skid at high power cruise, but this needs more evaluation on subsequent flights before determining the final resolution.
With power reduction approaching the pattern, the airplane immediately slows down due to the CS prop, so speed control response is rapid.
The airplane floats nicely in ground effect, making the landing flair easy.
Not a drop of oil on the cowl/fuselage after the flight!
Build time was 4 yrs, 3 mo. and 1665 hrs of hands on building.
The airplane is powered by a rebuilt Lyc IO-320 D3G by Premier Aircraft Engines at KTTD, with Airmotive SilverHawk Fuel Injection, Left Mag and LSE Electronic Ignition and Hartzell CS prop.
The panel is equipped with dual Grand Rapids Sport EFIS’s, GRT EIS-4000,
Conducting pre-flight safety briefing with ground support crew
LIFTOFF!
LIFTOFF!
ALL GRINS!!
ALL GRINS!!
