Brief Description: Trim Air Filter; Pro-Seal Filter & Flange for Bypa
Back to the FAB...
I marked and trimmed the air filter to fit around the accelerator pump and them mixed up a 1-oz. batch of pro-seal to seal both around the cutout as well as the flange of the bypass door. The flange for the bypass door was then pop-riveted to the bottom of the FAB.
Trim air filter to fit over accelerator pump
Pro-seal and rivet bypass door flange to bottom of FAB
Goop pro-seal over gap in air filter to seal around accelerator pump
