Brief Description: Install Air Filter and FAB while Pro-Seal Cures
Before installing the air filter against the carb I coated the accelerator pump protrusion with grease so the pro-seal would not stick to the carburator. I then gooped proseal over the grease on the pump as well as over the air filter cutout and then installed both the filter and FAB onto the carb. I'll need to keep this in place for at least 24 hours while the pro-seal cures to seal up the gaps.
