Brief Description: Bolt Baffles to Center Braces; Add Oil Cooler Brac
I bolted the front and aft baffles to the center braces that are in turn bolted to the engine case.
I also installed an extra brace for the oil cooler that is made up of a couple of eye bolts and a threaded hex tube that has reverse threads on one end. This allows me to adjust the tension on by turning the hex tube with a wrench. There is no longer any play or movement of the aft baffle that the oil cooler is mounted to. Hopefully this extra brace will prevent any cracking of the baffles. I still need to safety wire the hex tube so that it doesn't loosen up over time with all the engine vibration and heating and cooling cycles.
Aft baffles bolted to center brace; Extra brace for oil cooler baffle installed
