Dan's Web Site
RV-7A
Baffles
8-26-2009
Final Install Left Baffles & Oil Cooler
I decided to use steel fittings on the oil cooler rather than aluminum fittings. I used Fuelube on the threads and 90 degree elbows for both fittings.
Both the front and aft baffles were installed on the engine for the final time and then I bolted the oil cooler in place and connected the hoses.
Although I don't have a picture of this, I also painted a 2nd coat of white high-gloss rustoleum enamel on the inside of the top cowl.
Steel fittings installed
Left baffles and oil cooler installed
RV-7A Home
2363
Ailerons
Assembly
Baffles
134
110
Big Dig
Brakes
Canopy Frame
144
152
Cowl
68
74
Electrial
120
96
96
Elevator
Filtered Air Box
Flaps
Forward Fuselage
460
Gear
Hangar
Hardware
Horizontal Stabilizer
Left Aileron
Left Flap
Left Fuel Tank
Left Wing
90
117
Panel
Photo Shoot
25
Right Aileron
Right Flap
Right Fuel Tank
43
60
Right Wing
84
Rudder II
Seats
Service Bulletin: No
Spinner
Systems
Training
Vertical Stabilizer
146
