Brief Description: Rivet Right Inlet Floor - Parts 9, 10, and 10S
Today I deburred, cleaned, and alodined the right inlet floor parts - 9, 10, and 10S. I then used the pneumatic squeezer to rivet the reinforcement angle to the floor. However, I should have riveted the angle to the side panel first. There was no way to squeeze or shoot the rivets around the steep bend for the side panel after the angle was riveted to the floor. I ended up using Cherry Max rivets whereas I could have used solid rivets all the way around if I had riveted the angle to the side panel first and then to the floor. Oh well, moving on...
Right inlet floor parts cleaned and alodined
Part 10S reinforcement angle riveted to part 10 - floor
Part 10S reinforcement angle riveted to part 9 - side baffle
