Brief Description: Replace Lower Oil Cooler Fitting with 45
I decided to remove the oil cooler again today and replace the lower 90 degree fitting with a 45 degree fitting for better hose clearance from the engine mount. After reinstalling the oil cooler on the baffle and connecting the hoses everything looks much better now.
Oil filter removed and lower 90 degree fitting replaced with a 45 degree fitting
Lower fitting - much better clearance with the 45 degree fitting against the engine mount
Oil cooler reinstalled with much better hose clearance against the engine mount
