The top cowl was then installed and each camloc stud screwed in until it was flush with the top of each grommet. A quick push and counter-clockwise turn of the screwdriver released each camloc stud. The top cowl then had to be removed and the adjustment pin pulled from each camloc recepticle to lock them in position prevent them from turning. The top cowl was then reinstalled and viola,,it's done! MUCH easier to deal with than the hinge pins!
Camloc's adjusted and flush with the grommets - left side
Camloc's adjusted and flush with the grommets - right side
