Brief Description: Drill Top Cowl For Camloc Studs; Install
Next I used a unibit to enlarge the #30 pilot holes in the top cowl to 15/32" and then installed the camloc grommets and studs. It will be easy to remove the studs for painting later but I'm not quite sure how to remove the grommets with their retaining clips. Hopefully that won't be too much of a problem down the road when it comes time for paint.
15/32" holes drilled in top cowl for grommets and studs
