Brief Description: Bend & Install Camloc Recepticle Strips on Firewal
I bent each of the scalloped tabs of the aluminum camloc strip downwards just a bit to better match up with the downward slope of the top cowl and then clecoed these back onto the firewall. I also used a flat head screwdriver to raise each recepticle to be flush with the strip prior to installing the top cowl that has the camloc studs.
Camloc strips with tabs bent downward installed on firewall - left side
Camloc strips with tabs bent downward installed on firewall - right side
