Brief Description: Rivet Bottom Cowl Hinges to Firewall
I was able to squeeze all of the rivets for the bottom hinges. However, there were 4 rivets in the center section where there isn't a hinge that didn't have enough clearance to squeeze or buck them,,,2 under each of the main engine mount tube junctions on each side. I ended up using Cherry Max rivets in these spots. At least they are on the bottom where no one will see them.
Left bottom cowl hinge riveted to firewall flange
Both left and right bottom cowl hinges riveted to firewall flange
