Brief Description: Re-Safety Wire Alternator Tension Arm Bolts
After looking at several alternator setups at Sun 'n Fun I decided to re-do the safety wiring on the alternator tension arm bolts. Originally I had safety wired the two bolts together with only long twisted strand of safety wire. While there were a couple of planes that were done this way, most had safety wired each bolt to the arm itself. I think this is the safer way to go. If the long strand ever broke it could end up getting caught in the belt or pully and really cause some problems. Better safe than sorry. Each bolt is now safety wired locally to the tension arm.
