Brief Description: Pull & Tie the Tail Down to Raise Nose Wheel
Daisy and Stevie helped me pull and tie the tail down so I could start working on installing the new Matco nose wheel axle. I still had the concrete anchor bolt in place and I used a board across the deck to distribute the pressure from the tie down strap.
Tail pulled down with tie-down strap and concrete anchor bolt
