Dan's Web Site
Date:  10-24-2009
Number of Hours:  0.50
Brief Description:  Remove Nose Wheel; Punch Fork for New Hole
After removing the nose wheel I marked a center line on the fork, installed the axle bolt, and then slid the new Matco spacer onto the bolt. I then used a center punch through the 1/4" hole in the spacer to mark and center punch the fork along its center line for the 1/4" anti-rotation bolt needed for the new spacer/axle.
Nose wheel removed; Centerline marked on fork; Axle bolt installed; New Matco axle
Matco axle on bolt; Center punch for new 1/4
Matco axle on bolt; Center punch for new 1/4" anti-rotation anchor bolt
